very simply, if i run an LCD monitor at a lower resolution that its native resolution, will i damage the monitor at all, or is it just image quality that i lose?
You're not losing anything except size if it remains centered. Only running at a lower horizontal resolution and enabling scaling to fill the maximum size results in quality loss.
Auric: It's more than just a simple quality loss. It's not 1024x768 on a CRT 20". It's not only scaled, but LCDs have blurriness problems when scaling down from native resolution.
The only time it won't look like total crap is if you divide the native resolution by a whole number say 2. So If you have a Dell 2100FP which has a native 1600x1200 resolution you divide that resolution by 2 1600/2 = 800 & 1200/2 =600 . So if you run at a resolution of 800x600 it won't look too bad.
