- Jan 4, 2000
- 7,117
- 10
- 76
Hey,
This is kind of a physical/philosophical question.
When I drive to work, there is a large hill that I usually drive down in third gear. While going down this hill, RPMs are around 3K and I typically let off the accelerator during 80+% of the hill. I know that having a lean mixture and just compressing air makes a lot of heat, but how much is actually absorbed by the water jacket. (My engine has a floating piston arrangement, and the sleeves are not very thick)
So yeah, the whole fuel economy thing while in gear has been shot to death, but I think my way is slightly efficient because the thermal energy that would have been wasted in the braking system is now being used to warm up the coolant (which is cool from just starting my drive) in the engine. However, this could be easily proved wrong by observing all of the thermal energy escaping from the exhaust.
I guess I am wondering how much of that energy is transferred to the coolant while in vacuum. As far as observation, it seems too close to measure, with the temp gauge reaching op. temp around the same time, depending on lights. (My drive is approximately 5 minutes on local roads, until I get on the freeway, in which my temp is up to about 1/2 of op. temp, then the last 4th gear pull to freeway speed brings it the full way to op. temp)
As far as variables, I have a new radiator cap, thermostat, and coolant. Hill is about a 7% grade for about 1/4 mile. I was also wondering how different compression ratios might affect this as well.
