Running a Shutdown Script ONLY on Friday
bobber205
84
I went to Microsoft's website and learned how to specify a shutdown script.
However, the script I made deletes roaming profiles that are on the machine, minus a few administrative related ones.
How can I specify that this script is only to run on shutdown on friday's?
bsobel
Moderator Emeritus<br>Elite Member
Dec 9, 2001
13,346
I would need to know if this is a cmd.exe script, vbscript (etc) to be more specific. But basically have your script check for the day of the week and exit if it is not Friday.
bobber205
84
Thought I should at least post where I've gotten so far.
IF %DATE:~0,3% == MON ECHO "Today is monday"
does not echo "Today is monday" though when I just echo the data variable with those options it echoes MON.
Nevermind. Its Mon. No All caps.
bsobel
Dec 9, 2001
13,346
Just came in to tell you that, its' case sensitive but you got the rest correct...
bobber205
84
Sorry about wasting your time. Should have waited to post about another minute. :D
Aoleleb
57
Just use the built-in task scheduler in the control panel. Select the batch file and then select weekly and then select Friday then the time you want it to run.
bobber205
84
Wow.
Could it have been any simpler?
Thanks! :)
