Running a PSU "empty"
botanist
Hello!
I recently bought an Antec Sonata case supplied with a 380 W PSU.
Before ordering motherboard and other hardware to put in this case,
I wanted to check that the PSU works, so I plugged it in and turned
the switch on the backside from 0 to 1, but nothing happens. The PSU
fan isn't rotating. I've checked some molexes with a volt meter but no
voltage is indicated. So now I wonder:
Is there something wrong with my PSU, or is it only supposed to work
when connected to a motherboard?
My retailer isn't answering calls between the holidays so I hope
someone here on the forum can help me. Thanks in advance!
Botanist, newbie when it comes to building computers
Lol, wait until it's connected, it's the only way to test it....it doesn't just *work* when you flip the switch on the back. 😉
Get a metal paperclip and bend it into a "U" so that one end fits in the green wire (there's only one) and one fits in a black wire (any one will do). You can then use the "hard" switch on the rear of the PSU to turn it on and off. This is a good way to test a PSU away from components and out of the case.
Oh, and welcome to the forums. 😀
Thanks "high" and "beatle"! I've tried the tip with the paperclip
and it worked just fine. I feel so much better now. 😀
So great to have kind, knowledgeable people to ask.
Thing is, you shouldn't power up a switching PSU without a load, but a brief on-off shouldn't hurt. Here's hoping...
. There are testers you can buy for about $10. that provide a minimal load. www.svc.com carries a couple of 'em.
.bh.
