So has anyone tried this before? right now i have a thermaltake armor (original, the one without the side fan), and i am really unhappy with its feature set and wire management options vs what newer cases have, and it's airflow isnt really that great. i have always had better temperatures across my system with the door off vs with it on, and i have stopped using the 92mm fans in the top and by the PSU/top HDD cage since they werent helping my HDD temps any and my cpu vents out the back.
Now, right now i have 2 of these fans mounted on my megahalems with fan silencers, one mounted a foot from the cooler horizontally where my HDDs are sitting in the 3 in 3 bracket, and a 4th in the back vent on my case about an inch from the cooler. all 4 fans are blowing in the same direction, creating a sort of wind tunnel across my CPU (basic specs in sig). As you can probably tell by now, im big on the silent factor, and im looking to get a case that has excellent hard drive mounting options, wire management, is alluminium so it's lighter, and has high airflow. I have decided on the ATCS 840 as my case of choice, and i was wondering if anyone has tried running a passively cooled configuration with this case.
I have a Megahalems cooler on my CPU, and under linpack my cpu doesnt really go passed 70c (at 68c as i write this under linpack), so i was thinking that if i had enough airflow (2x230mm fans and a 120 all in close proximity pulling air out) i might be able to get away with not even having any fans on the cooler at all.
so has anyone tried this configuration before? i dont really need a higher OC than what i have, and making my system even quieter would be great if i can pull it off. given, i probably wont notice the difference, but it would be a fun experiment anyway.
