Hi.
I'm thinking about getting a new machine and overclock it. I'm already set with what I'm gonna get (Q6600 and Gforce 8800 and some other
nice stuff).
My concern here is heat, but I'm not concerned about heat inside my machine because I've already read through tons of good guides about that.
I'm concerned about the heat that the machine will cause in my room. I already think its too hot from 1 laptop and a non overclocked single core machine.
So I assume that my new mahine will produce quite alot of new heat that I dont want.
After looking around for solutions and not finding anything that seems to work well except having a ACC running I came up with another idea
(ACC will be to expensive I think).
If I put my computer in another room where it doesnt matter that much if it gets heated the problem should be solved.
So I'm looking for a way to put my highend machine in 1 room and have still have access to all ports.
all USB , parallell port, DVI port, Sound ports. So I can use my machine. I would also like to connect a external DVD drive so I dont
have to move my ass everytime I need to change DVD in the drive.
Is there some kind of hardware for this?
I would need to connect all of my ports on the comp to 1 "hardware" that is connected with 1 cable to my other "hardware" that I can connect all my diffrent devices to.
Anyone heared of this and know a solution?
I dont want to have 30 meter cables for every device running all the way from my comp room to my working place.
nice stuff).
