Running 2 Operationg Systems
CyNics
Does it possible to run 2 operating systems at the same time using the same machine using 2 diff. monitors if I had enough processing power and memory to handle it? Each OS will be installed into 2 diff. HD.
I'm just curious 🙂 Thanks 🙂
emu=emulator.
An example would be VMWare which allows you to run Linux while booted up in Windows.
