Motherboard:
<LI class=name style="WIDTH: 325px">GIGABYTE GA-Z87X-UD3H Z87 S-1150 ATX Memory:
KHX1866C9D3K2/8GX 8GB 1866MHz DDR3 Non-ECC CL9 DIMM (Kit of 2) XMP Kingstone
Well, I try to runt the memory on 1866mhz with 1,65v but the processor then overclocks automaticly to 3,8 mhz and i dont want that. I there some bios settings I can change this. I have found a cpu ratio I can put on 34 but then the processor wont do the turbo to 3,8 which it is capable for...
What to do? or do I have to runt this memory om 1333mhz so the processor dont overclock. I also tries to run the memory on 1866 with 1,5v and it seems to work, but the processor then still overclocks to 3,8!.
Is there something to do or is it ok to runt the processor on 3,8... reason I dont want to overclock is that I have stock cooler and running prime it hits around 100degres! and on stock its around 80 to 85 maximum.
Can i make this work or should I buy a cpu cooler and be happy...
