Just saw that ad. Hopefully they added an SD cad and replaceable battery.
S5 has got one.can you please explain to me how in the world you think they could affordably add a replaceable battery to a waterproof phone
Nice battery, but why ATT exclusive. ATT gets all the good phones. I may need to switch.
"Colors: Camo White, Camo Blue, or Gray"
Camo white is hardly camo unless you are in a snow storm.
Build it like the S5?can you please explain to me how in the world you think they could affordably add a replaceable battery to a waterproof phone
S4 active was waterproof with removeable back, the back just had a gasket on it. I took mine into the pool and it worked great. S5 standard AND active both had removeable backs and were waterproof.
Any other questions?![]()
Wut? If you're talking about the S5 as many times as you want. I don't think that the S6 has a removable back.I question how many times the back can be removed and reinstalled
He's thinking that over time, the gasket on the S5 ACTIVE is going to degrade and stop sealing properly.
I believe there is a property of plastics called...hm...plasticity...that determines this. like metals. some will deform permanently. some maintain rigidity after a flex, assuming they don't break. aluminum allow would be an example
more that the plastic is going to flex and deform from original.
I rip mine off at least once a day and it's fine (I don't charge, I just stick a full battery in).more that the plastic is going to flex and deform from original.
They only cost a few quid to replace anyway.
Aluminium is a poor choice of metal to use if you want to avoid metal fatigue. Spring steels (and few other alloys I think) are the ones that can bend (to a certain point) infinitely without permanent deformation.
In any case, the GS5 will maintain its waterproofness over more battery back removals than most people will even come close to.
Given the thousands of reports of it not holding it's shape, I think you are on to something. Good job!yes, but I'm talking about it maintaining its shape, not whether it can bend or not
The seals on the cover on the S5.I don't know about the regular S5, but IIRC on the S5 Active, the rubber seal was on the phone back not the battery cover. I could be mis-remembering, though.
:awe:Given the thousands of reports of it not holding it's shape, I think you are on to something. Good job!
