- Sep 28, 2001
- 5,493
- 3
- 81
Well considering typical Nexus prices, that's one very compelling reason to get it over the One.
Plastic. Ugly.
Mostly same specs as HTC ONE but with a lower DPI and probably worse all around screen.
No reason to get that over the ONE IMO
Shows how much you know.Plastic. Ugly.
There's exactly one AWS AT&T LTE market, I believe, somewhere in Oklahoma.
Then again, even if they launch an LTE model... there's no guarantee Verizon will allow it to be on their network. Because they're rude like that.
If they make no hardware changes, and simply enable the LTE functionality on the handset, then it won't work with Verions current LTE setup anyways. The good news is that Verizon looks is heavily invested in AWS, and will begin deploying sites this year. So the N4 could conceivably work for data on big red. Voice on the other hand...
Of course, Google could surprise us with a tricked out N4 that supports all the 700mhz range for LTE and all bets would be off. I wouldn't expect to see a CDMA Nexus 4 though. Verizon's nasty taste is probably still all in Google's mouth.
What alliance?I commented on this on an article earlier today on PocketNow.
If Google and LG do release a version that has the 700 mhz block added, it will work only with data on Verizon. They would have to physically add a CDMA radio to it for it to work on voice. Since Verizon's back end is CDMA, whatever phone that's built for VZW needs to have CDMA built into it for it to make voice calls. In 1-2 years, Verizon will have refarmed some of their CDMA spectrum to use for Voice Over LTE.
Verizon is in this open handset alliance. They say they'll allow any phone on their network as long as it's built to specifications. Well, they need to include CDMA to work. Most OEMs will not build a special version of their device just to work on Verizon which is why VZW only has a handful of phones when you compare it to ATT and all the GSM devices out there.
I'm holding out the slightest bit of hope that Verizon and Google will work out some deal to offer the Nexus 4 with LTE.
Around the world, most people use T-Mobile's bands. 1700, 1800, and 2600 are used almost everywhere around the world. AT&T's 700mhz? Nowhere else in the world uses that.Screw Verizon. If they want the phone to work with Verizon it means they practically need a carrier-phone. We know how that works.
An unlocked HSPA+LTE phone is what they should keep it. The question is what LTE bands do they add? Probably official LTE for T-Mobile. Hooray for AT&T users and everyone around the world. A tiny fraction of people benefit.
Of course I could be wrong and maybe they add some global LTE bands including some in the 700mhz region. That would be a killer.
But as QueBert mentioned, there's still a lot of battery work to be done on the Nexus 4. While Google may be serious about improving their OS, they're not really squashing any major bugs on the Nexus 4 yet.
http://en.wikipedia.org/wiki/List_of_LTE_networks
So your statement should probably read "Probably official LTE for T-Mobile and a lot of places around the world. Hooray for AT&T users. A big fraction of people benefit."
What alliance?
They're certainly not listed here.
http://www.openhandsetalliance.com/oha_members.html
i would buy it just for fun if it worked on verizon, but id hope they would take the opportunity to make some design changes also, like a larger battery, a non glass backing, more memory and a newer chip. lg is really a second rate company, id rather have a nexus from a company like motorola
It's pretty trivial to re-enable LTE on 4.2.2 if you have a reason to.
I can see why they didn't have it on initially and I'm fine with 16GB of storage, so...
