Rufus boot USB working for XPblackSP3 and not for other XP's ?
Status
Not open for further replies.
siagur90
37
This working fine: Windows XP Professional SP3 x86 - Black Edition 2015.4.19
This other XP doesn't work and i receive the message:
PROFESSIONAL SP2 Ferrari -dones't work
Microsoft® Windows XP Professional SP3 x86 Integrated April 2014 - Maherz -doesn't work
Windows XP PROFESSIONAL SP3 Dec 2014 + SATA Drivers [TechTools.net] -doesn't work
Code:
A problem has been detected and windows has been shut  down to prevent damage to your computer. If this is the first time  you've seen this stop error screen, restart your computer. If this  screen appears again, follow these steps:
Check for viruses on  your computer. Remove any newly installed hard drives or hard drive  controllers. check your hard drive to make sure it is properly  configured and terminated. Run CHKDSK /F to check for hard drive  corruption, and then restart your computer.
Technical information:
*** STOP: 0X0000007B (0xF78d2524, 0xc0000034, 0x00000000, 0x0000000)
Windows XP [/CODE]
I'm sorry. The Anandtech Forums are not a place for asking for help installing pirated software. -Admin DrPizza
Fardringle
9,200
765
Try using a legal copy of Windows. Both the "Black" and "Ferrari" versions are pirated copies that are not only full of malware, but are probably missing important kernel functions that are needed for the boot disk to work properly.
redzo
547
Pirated OS's having problems? Say it isn't so!
Xp(be it pirated or not) is a pain in the a** to get it to install from a non-native cd-rom boot or pxe environment. After the second stage install, get ready for countless BSOD's. Just leave Xp die in peace! Xp's install/setup it's build around too many legacy principles. Xp's install environment doesn't have a clue of what a usb flash is.
From another perspective, starting with Windows 7 , usb flash installs have become butter smooth and reliable for those in need of fast installs(better than dvd-boot).
Ketchup
14,559
248
This site frowns on pirated versions of Windows. Try a legal version and see if you have the same problems.
Status
