Ruddy lag and stuff by a noob
thefastestfox
13
Hi everybody! I was hoping someone could help.
I'm currently running an AMD Athlon(tm) 64 X2 dual core processor 3800+ 2.00 Ghz 2.00 GB RAM with an RV530Xt graphics card plus an RT6x Wireless lan card and it's all connected to a BT home hub. So far so good.
The problem is my connection to the free online game Wolfenstein Enemy Territory. It used to be fine but now it's terrible. I can access the servers sometimes but usually after maybe a minute of normal play the dreaded 'Connection interrupted' comes up and the screen freezes. Then it might come back again or kick me for 'unknown reasons'.
Is it because I have a low siganl to the Home hub?
Also, could it be that my bro who has now started playing the same game on his wireless laptop next door (literally a few metres from my pc) is a factor? Could his signal somehow interfere with mine?
When the three computers (2 pc's, bro's laptop) in the house are 'on', will this cause a drop in performance in my gaming? If so how can I speed it up?
Sorry for the long post. Any thoughts/ideas/would be helpful. Thanks
Canai
8,016
Try running wired and see if it fixes the connection problem. I've seen lots of problems when gaming over wifi, especially with multiple people doing it.
Canai
8,016
Also, what is your ping when you are playing, and does it skyrocket right before you get disconnected?
