fleshconsumed
Managed to score 3070FE from BB a few days ago. It's my first nVidia card in 6 years for me. The cooler is not great, but lowering voltage curve and power limit helps a lot to keep the noise kind of reasonable. I'm having issues with zero rpm feature. My fans always keep spinning at 1000RPM.
To summarize:
- 461.40 drivers and MSI Afterburner 4.6.3 beta 5
- Fans always spin at 1000 rpm no matter what I do
- Core clock varies between 600-1000Mhz, memory clock 810Mhz, power used 30W (multi-monitor setup with 3 monitors), current GPU temp 39 celcius
- I've tried shutting down MSI afterburner and fans still spin
- I don't think I have RTX Broadcast installed (how do I check?)
No matter what I do fans always spin. Does RTX 30 series not have zero RPM fan feature? Can I set it somehow to stop the fans in idle?
To summarize:
