RT311 problems
friedrice4u
36
I get occasional disconnections from HTTP... I can still use ICQ or AIM... but my browser doesn't work...
pinging addresses also do not work... but it comes and goes...
ne suggestions?
jmcoreymv
Are you sure you can use ICQ and AIM? because if you cant ping (icmp) which is a network layer protocol, I dont see how using anything that runs above it on the tcpip model able to work.
SuperKen!
533
I get that exact same problem sometimes, its not the RT311 that is causeing the problem, it was my DSL service experienceing heavy packet loss.
Try getting in touch with your CO to fix that problem.
