RPM monitoring fans for SLK900U
borgmang
335
I'm looking for a fan for my SLK 900U. I ordered a Panaflo 92mm L1A, but the F***in fan came with bare leads and I can't find a connector anywhere. I know I need to order either a 3 pin molex connector or some sort of tail that I can swap out, but I need a temporay fix to assemble my new PC before the weeks up on the CPU.
It would be great if any of you guys can tell me which RPM monitoring fans I could get at Frys until I find a place and order the right connector for the Panaflo. I need to go and buy this tommorow so I can put this system together. I plan on taking the fan back ti Frys after I get the Panaflo going. Also, please let me know if anybody knows where to get the correct connector for the Panaflo fan. Here's my system below. Thanks in advance.
Motherboard: ASUS P4C800-E Deluxe
Processor: P4 3.0C
Case: Cooler Master ATC-201B
Power Supply: Antec True480
Cooling: Thermalright SLK900U w/92mm Panaflo
RAM: 1 GB 2x 512 Kingston HyperX 3500
HD: 2x Raptors - Raid 0 and 1X WDSATA 250GB
DVD-RW: waiting to buy for a while
DVD/CDRW: Samsung SM-352BRNS-2mb blk
Floppy: Sony - blk
Video Card:ATI 128 9800 Pro
Sound Card: Sound Blaster Audigy 2 Platinum
Keyboard/Mouse: Logitech MX Duo
OS: Win XP Pro
borgmang
335
I hate to bump, but I really need all your guys help on this so I can buy a fan tommorrow. Thanks.
Cerb
17,484
33
86
to quote myself:
Enermax adjustable 80mm
Enermax thermal control 80mm
YS-tech adjustable 80mm
For the SLK-900U, I would think the thermal control, since it's cheaper and still should be plenty of air for the HS. The Enermax (Compuman) fans I have used myself, and found them to be quality fans.
borgmang
335
Originally posted by: Cerb
to quote myself:
Do you think Frys would carry this fan?
RalfHutter
3,202
Fry's usually carries the adjustable Enermax fans. Whether they'd have them in stock is always a crapshoot with Frys. :)
