Router Problems...please help
WoodiE55
768
Hey guys I have a T1 line connected into a SMC 4port Router/print server with a built in NAT firewall, The firewall works like a charm from the internet tests i preformed on it. All stealth. The problem is that i think it works to well. I play Team Fortress Classic (half life add-on) and i also host a server on my other PC. But when i host the server its not found over the net. I believe cause its the firewall. Does anyone know how to fix this and what i need to do. I have already looked at SMC's website and there isnt anything helpful. Any help would be nice!!!!
Thanks
WoodiE
Jul 12, 2001
62
http://server.counter-strike.net/cgi-bin/Ultimate.cgi?action=intro
Try these forums..These guys can help you out. And you may even find someone else with the same problem. But you need configure your firewall to allow the port which TFC uses to allow traffic in. In Counter-Strike it is 27016 by default but I am not sure what it is for TFC. What port is TFC using to serve with?
Check out the other forums though at that site above. They can help.
