fitzhue
Hello everyone, I have a question for all the router configuration guru's of AT. I'm having problems configuring a 3 router, 3 workstation, 1 switch topology in Cisco class. I am almost positive I am doing everything right. All the routers are 2501 series routers.
Router_A is hooked up to Router_B via s0->s1. Router_B is hooked up to Router_C via s0->s1 as well. I configure all the interfaces on the routers just fine including clockrates on the DCE cables. I configure all the ethernet addresses just fine and i make sure to double check that the ip addresses are right. But i still have some interfaces that don't want to ping. I configure each router the same but obviously taking into consideration the different ip addresses. Some interfaces will ping fine and others won't. I can ping 2 out of the 3 workstations.
Does anyone have a clue as to why some interfaces will ping while others wont? Does anyone have a checklist maybe to make sure i'm doing everything right? Even some sort of website, maybe on the cisco site because i couldn't find anything, that shows how to do all of this correctly would be extremely beneficial. Let me know if there's any other information I can provide as this problem has been bothering me for almost a week.
P.S. my teacher isn't exactly the greatest at configuring routers either as he just graduated from sem2 a few weeks ago.
Thanks in advance.
Thanks in advance.
