- Feb 20, 2002
- 2,334
- 37
- 91
Ok first of all I'm getting a new case and I would like everything to look rather spiffy when I get it together. Here is my question: I just got a new Enermax whisper 431watt psu and the power cable for the mobo (the big one) has a sort of wrap around it to keep everything neat. It looks sorta like a chinese finger trap as when you push it together it expands...and when pulled tight it contracts around the wires. I would like to buy some of this stuff to use on some self rounded cables and the rest of the psu wires. Anyway I don't know where to get it...or what it's called...so that is my delema. I was at caseetc.com and they sell "split loom", this sounds like it could be the product I'm looking for...however I'm not sure because the picture is so small. Anyway remember that this isn't like spiral wrap as it isn't cut in anyway...it's a solid tube (like the finger trap). You push it together to make it bigger and fit over connectors...and then pull it tight and tape it down at the ends to keep it taunt.
But...what is it called?
