Roughly how much brake fluid is needed to flush a Corolla?
Sukhoi
15,342
104
I just need a rough idea of how much to buy. Is 32 oz going to be way more than enough? Should I buy 64 oz?
MiataNC
2,215
It really depends on how much fluid you want or need to flush through the system. 32oz should be enough to flush most systems.
That valve thing works awesome.. I've used it on my motorcycle (similar one) .. changed my fluids in < 15 minutes.. (thats including the snags i ran into).. actual fluid flush on my bike was less than 2 minutes in total.
SO get one.. just make sure someone keeps an eye out for clean fluid coming out of the nipple end and refills the main cylinder.
thecritic
470
I use a Motive Pressure Bleeder and 1 quart is more than enough to flush a system.
If you're using a pressure bleeder, make sure you use a dead-blow mallet and tap the caliper continuously during the bleed to dislodge any trapped air bubble. The same applies if you are doing a manual bleed, just tap it before you open the screw.
