Right now I've got a rotary pump in a system where the discharge pressure is about 350psi, and the nominal max is 200psi. One of my supervisors tells me that it's bending shafts and whatnot, in addition to delivering poor flow at the end of the system (which is weird, because it's a rotary); now, the pipe is 2" stainless steel and the fluid is something about as viscous as Vaseline. He's considering moving to 3" to relieve the pressure at the pump discharge.
As a cheaper measure to reduce discharge pressure, one of his colleagues suggested doing something like this:
http://www.rootminus1.com/howard/pics/pump.png
where the parallel pipe is the suggested installation. The system resistance would probably drop a little, lowering the discharge pressure, but as far as I know it would be just like upping the cross-sectional area for a part of the pipe.
Can somebody help me get started with the calculations to find the drop in discharge pressure for moving from 2" to 3" pipe? I can get the length of pipe, minor losses, viscosity of fluid, etc. The nominal flow rate of the pump is 50GPM, but it doesn't sound like it's delivering that much.
Pointing me to the right formulas would be great.
