I havve a node not giving credit. It seems to run normaly, reports results with no CPU time. . I posted in the problem area at the rosetta site. Since then I discovered the graphics are broken on that rig. I would just reinstall every thing but I would like to keep the node number and ranking. Anyone know how to do that ?
It can be done. Its not 100% foolproof, not endorsed but not completely frowned upon either.
As long as you keep the same OS(XP, W2K, etc) this should work*
Backup the entire bonic directory, move it to someplace safe.
If your going to start from scratch (ie wipe HD, new HD), reinstall OS, reinstall bonic, do not attach to any projects (will get new node if you do), copy your previously backeduped bonic directory(s) over the new installation, start bonic
If not starting from scratch, uninstall bonic, delete any remaining bonic directorys, clean out the registry of any bonic info, reboot, reinstall bonic (again don't attach to anything),
copy your previously backeduped bonic directory(s) over the new installation. start bonic.
Everything should then work fine with your old node number.
This worked for me on a couple of occasions. This host
http://setiweb.ssl.berkeley.edu/beta/show_host_detail.php?hostid=325 started life as a Celey 900.
They are going to have to pry my low node id's from my cold dead hands.
*disclaimer...it worked for me, may not work for you. Worst case, you get a new node ID. YMMV. Not safe for children under 6, etc.
