Roomie clogged drain with mac and cheese, how to unclog it? EDIT: PROBLEM SOLVED!
CarlKillerMiller
3,099
I get back from class today and pour myself a glass of water from the tap. I notice that the water that's in the sink isn't draining, so I grab a flashlight and take a look. THe inside of the drain is quite literally packed with macaroni noodles.
He left and I need to use the sink for dinner, so I've been pouring boiling water down the drain for the pas thalf-hour or so, with no noticeable effect. This being a college apartment, we're missing a lot of stuff like a plunger or a drain cleaner. Should I go out and purchase em, should I wait it out (Maybe the macaroni will harden overnight, be easier to remove?) or is there some third option?
Thanks, ATOT!
The winning soution was Jtoxic's, to remove the u-pipe and clean it out from there. That was really goddamn nasty, I'm going to punch this kid when he gets back.
Ika
14,264
maintenance guy sounds good. I can't think of any carbohydrate dissolving substances off the top of my head, though...
FrequencyX
327
Pour 1 cup of baking soda down the drain followed by 1 cup of hot vinegar. Try heating the vinegar in the microwave before adding it to the drain. Wait 5 minutes before flushing the drain with 2 quarts of hot water
But than again, I don't think it will work to well in breaking down those solids.
Leros
21,867
7
Get under the sink and take the pipes apart. If you look where the drain U's at the bottom, the U peice usually unscrews and comes off.
Eli
Super Moderator | Elite Member
8
Originally posted by: BrunoPuntzJones
Originally posted by: isekii
then try using a straightened out wire hanger and start poking at it
But that mac and cheese has a right to life!
OMG!
LMFAO!
