- Jun 13, 2000
- 26,391
- 1,780
- 126
I've got a Roomba 665 (I think that's the model) that I bought. I replaced the side brushes with some I got off ebay and the screws were threaded differently. They quickly stripped the nylon/soft plastic threads in the motor. I've been trying to repair this thing for ever, but keep hitting snags. I've tried a few types of super glue and gorilla glue to fill the hole and basially retap. I read that epoxy doesn't work well to do this kind of repair. I tried super glue, but it cracked an came out.
Gorilla glue forms small air bubbles in it as it cures....almost like a foam. This was good because I was able to add a little more as it cured and tamp down what was there without it sticking to the dentistry tools I used to pack glue down. It worked for a few cleanings, but eventually it couldn't handle the torque. I found a youtube video with a guy using bondo, but I don't have any and he never posted back to say whether or not it held up. If I can't fix it with glue I have, I'll put up $30 and replace the motor....just curious if anyone has any other ideas on how to repair it (or a source of good motors that are less than $25-30)
=P
=P
