Originally posted by: SparkyJJO
The CPU is still using the same amount of power regardless of whether it is at 60*C or 40*C. Same amount of heat is being put out.
Now, the new CPU cooler is more effective at moving the heat from the CPU to the air (making the CPU run cooler). However, that heat goes to the room air so technically your room could end up a little warmer than before you put the new HSF on the CPU.
First statement is so true. In an ideal world, you'd have perfect heat transfer from the CPU to the case air, and from the case air to the rest of your room. Disregarding efficiencies (i.e., I2R losses in the CPU [
typically, resistance is linear with temp], convective mixing, conduction from CPU to HSF, yada, yada, etc.) both cases would yield the same mean temp in the room (where phile was coming from). In more detail, you've got a higher temp w/lower flow rate that should equal the lower temp w/higher flow rate, and all this is mixed perfectly with the surrounding air in the room.
However, in the
real world, with the hotter CPU config, the air exiting your case will be hotter (again, disregarding the case), so depending on your room's convective characteristics, you would actually feel HOTTER in this instance next to the computer as your CPU builds a nice "cloud" for you to enjoy while you're playing at your desk.
Interesting question.
PM
