- Aug 28, 2004
- 146
- 0
- 0
Hello,
I screwed up my PC big time and need someone's help. I played around with a setting in my BIOS that I should not messed with, I admit it. As soon as I made the change, the PC promptly shut down, nothing. When I try to start it up, no screen whatsoever comes up to allow me back into the BIOS to change the setting back. Fortunately, I know what setting I changed. I went into this setting:
Freq. Volt. Control, the next section reads:
CPU Host/SDRAM/PCI Clock, the choices for that are:
default (currently selected)
100/100/33 MHZ
100./133/33 MHZ
100/166/33 MHZ
105/140/35 MHZ
108/144/36 MHZ
112/140/31 MHZ
100/200/33 MHZ
133/100/33 MHZ
133/133/33 MHZ
133/166/33 MHZ *************************************
133/160/33 MHZ
The original setting was on default. Like a fool, I went and changed it to the setting with the asterisks next to it. I don't have a rescue disk either. How can I get into the BIOS when I can't even get a screen to come up? I pressed F8 trying to get it to come up in Safe Mode and that didn't work. I also tried Holding "delete" as it tried to boot, no luck there either. Any help would be deeply appreciated. I opened up the case and the CPU fan and video card fan still work, so I guess I didn't fry anything. Please help, I'm desperate as you can probably tell. Thank you.
Sincerely,
Hans Groenewold
100/100/33 MHZ
100./133/33 MHZ
100/166/33 MHZ
105/140/35 MHZ
108/144/36 MHZ
112/140/31 MHZ
100/200/33 MHZ
133/100/33 MHZ
133/133/33 MHZ
133/160/33 MHZ
Sincerely,
Hans Groenewold
