How far under 1% are the fuel trims? Up to -8 or so is fine, more than that and you're probably looking at a vacuum or intake leak. How were you using the wd40 to test for leaks? Easiest way I've found is spray around every sensor, seal, hose or piece of rubber with throttle cleaner and then watch for the fuel trims to go more negative.
I'd also +1 what lsd said, If your throttle body is drive by wire then you need to start with doing a relearn for the throttle position; the more dirty the tb was, the more you need to do it.
as in, within 0 to 1%. :/
on my 06 scion tC 08 engine, thankfully there's a limited number of connections and they're all near each other. I sprayed around all of them,,,, but wasn't watching the trim just listening for the idle.
throttle body is electronic.
I guess I'll get around to seeing if I can find what I read originally.
additionally, on start the car doesn't get fuel for more than a split second and dies so I just hold the key in the start position for about 3 seconds in stead of 1. It's almost like transponder isn't transponding to permit fuel to go into the cylinder, except that it is, if only for a quarter second and then cutting out. and everyone tells me fuel pumps don't fizz out.
I don't think these issues are related as the rolling idle has been this way for years and I don't think it's likely a problem. The other thing and a rough idle/die sometimes randomly are new since the AC was recharged.
