Cheetah8799
To all you fellow road cyclists.
I have a set of Look pedals (don't remember the model, higher end though) and the red cleats. My old cleats, which weren't used that much, have worn down the contact point with the pedal and the base of the cleat so that they were very smooth. Then when I would pedal, and slightly shift side to side sometimes, the contact point with squeek. So I bought new cleats, they worked great for about 30 miles, then started squeaking! I noticed the new cleats also are worn smooth already.
The paint on the contact point of the pedal is worn off. Right where I think the squeek is coming from.
I've tried using some light oil to lube it, but that only helps for maybe 20 - 30 miles.
I don't think it's being caused by dirt. I make sure my pedals are clean if possible. I think maybe just the worn off paint is causing the problem.
Anyone know how to solve this problem? Does the base of the pedal need to be re-painted?
thanks. I can take some digital pics of the pedals and cleats if anyone thinks they can help.
-Josh
-Josh
