rmdr.iq not found
crazychicken
2,081
When i turn on my computer, i get this error. I think it is related to my HP officejet 600. does anyone know how this is caused and how to fix it?
lmk
david
r0tt3n1
1,086
Apparently you havent registered your HP product yet. That file is part of the `reminder` function of the HP software. Using Add/Remove Programs in Control Panel, un-install the HP software, reboot then re-install,that take care of it. Or, edit the win.ini file and remove the `remind.exe` from the "load=" line of the [windows] section. hth
