RMAing my Sapphire X1900 XTX. Replacement?
Anogar
102
I recently bought an X1900 XTX. It seems to be screwed up. It gives me these crazy red lines horizontally when I try to set it at 1600 x 1200. The monitor is fine (which is also new) I just tried it with my buddy's computer, and it's fine.
Ideas?
Anogar
102
Bah. I don't want to replace the card, it rocks... Screw it, I'll figure something else out. Ignore this thread.
akshayt
Banned
Feb 13, 2004
2,227
even after RMA you will get the 1900XTX or maybe 1950XTX if you give this card after soem time. Whats the prblem then?
Keysplayr
21,219
55
RMA it. You paid good money to be able to use it without issues. Might as well put that warranty to use.
Anogar
102
I think that maybe the issue is that one of the DVI ports is somehow malfunctioning. That's what ATI thought at least. Does that make sense? The card works perfectly with CRT monitors, but with my new LCD it acts a little weird. I have it mostly resolved, it's hardly visible, but still there. I'm getting a new monitor in a few days, I guess I'll see if it does it there too, and make a decision.
