BehindEnemyLines
For RLC circuits, the Kirchoff's theorem tells (for my particular circuit) as q/C + IR + L(dI/dt) = 0 so L(d^2q/dt^2) + R(dq/dt) + q/c = 0. So the charge as a function of time is defined as: q(t) = Qe^(-t/2T)*cos(?t+F), where Q = q maximum, T = inductance time constant, ? = angular frequency, and t = time (seconds).
EDITED: Note above that the capacitor is first charged to Q and then place connected with a resistor and inductor together in series.
However, what would happen to the q(t) if there's a fixed applied voltage (DC voltage) in the circuit (RLC + battery)? Again, using this loop theorem: L(dI/dt) + IR + q/C - e = 0 ==> L(dI/dt) + IR + (1/C)q = e. If I then differentiate: L(d^2q/dt^2) + R(dq/dt) + (1/C)q = 0 since e is a constant. However, this gives me the q(t) like a LC circuit. But I'm stuck in solving for q(t) with the additional constant emf battery remains connected in the circuit. I'm not sure how this would change the overall equation of q(t), if any???
