Amdfanboy is right. Use the standard stranded copper RJ-11 patch cords between your analog device and the wall jack. Solid-core cable should not be used in a situation where the cable is going to be moved around, since the wires would eventually break inside the insulator jacket. Just use as short a patch cable as you can get away with, and the attenuation and crosstalk will be negligible.
Your Cat5e should be run from the back side of the RJ-11 wall jacks to whatever type of patch panel you are using for your voice cable runs, like a 66 or 110 block. It is the same with the data cable runs. You run Cat5e solid-core cable from the back of the wall jack to a patch panel, then use a stranded patch cable to connect to your network element (hub/switch/router/server/etc).
If you aren't using any kind of structured cabling, and this all seems like too much trouble, then just strip back the jacket, clip the 4 wires you aren't using, and crimp the RJ-11 connector onto the remaining 4 wires with no strain relief from the jacket. It will work like a charm if you never move it.
What Spidey07 means is use an RJ-45 wall jack, and just plug an RJ-11 patch cable into the jack. It won't be a secure fit, but it will hit the 4 middle pins.
