riva tuner question
Rhonda85
I am attempting to o/c my geforce mx 440 card and installed riva tuner. How do I know that it is being overclocked? Do I need to have the box checked where it says "run at windows startup"? Lastly, I put my PC in suspend mode when I am not using it; there is an option to "restore clock frequencies after suspend mode" Do I need to have that checked?
Thanks...
I think that if you use coolbits you can overclock thru that, i use rivatune all the time but i dont overclock with it, i use coolbits you can download it from the 3d guru main site.
