If you're not raising the voltages you won't damage anything. Even if you are raising voltage, it's pretty difficult to do actual permanent damage. Your motherboard is not designed to fry processors.
If your not raising voltages, the extra clock speed will still damage the chip
Why? How? Do transistors have a certain number of 'switches' in their life and then they die?
Cpus are made using gates based on cmos transistors...
Yes, thanks, I do have a compsci degree y'know
What I don't have is an EE degree, so I'm not sure how the _individual_ transistors behave from a physical point of view.
I was just wondering if they degrade more simply by switching more often. I guess if you say a transistor can conduct X amount of current in it's life before dying, then either raising voltages _or_ raising clock speed would affect it in the same way - but that's not how they work is it? If my CPU can switch 1V for 10 years, that reasoning would mean it could switch 2V for 5 years, which of course isn't true...
This makes me think the current switched each time is _way_ more important than the number of times it it switched.
