- Sep 21, 2002
- 19
- 0
- 0
I'm using a P4 2.8GHz processor on an Asus P4T533 mobo; with a single 256MB Samsung RIMM4200. Here's my problem: Whenever I specify my FSB speed as 133MHz QDR (which makes my CPU run at it's default level of 2.8GHz and effectively makes my memory bus 1066MHz) my system locks up after about five minutes of doing anything CPU-intensive. However, when I lower the FSB speed to 100MHz QDR (which makes my CPU run at 2.1GHz and effectively makes my memory bus 800MHz) my system becomes perfectly stable. I've already verified that my memory module is indeed a 32-bit RIMM4200; also my CPU's temp never exceeds 105 F. Here's what I think is causing the problem: The 32-bit Samsung memory module is made to operate at 2.5V, not 3.3V. However, when I open then Asus Probe software in Windows XP it tells me that my current memory voltage is 3.344V, as opposed to 2.5V. I thoroughly checked the Bios and there's no where I change the memory voltage. I plan on calling Asus on Monday, but I was hoping to gather some input before then. Any information you guys can provide on remedying this problem would be appreciated. Thanks.
