Right Click >> View Source not working
Unsickle
1,016
IE simply ignores my request. I've done my google research and suggestions are to flush cache, but it no workie.
WinXP with IE6. Anybody have a fix?
Unsickle
1,016
Thanks for the MS Knowledgebase links... I've seen them and they're not very helpful.
I'm still hacking at it... tried reinstalling IE6, didn't work. Bah.
No such "noviewsource" in the registry either. Cleared cache/cookies, restarted, etc. Still searching for the magic bullet.
WombatWoman
5,439
Did you check to make sure that Notepad is selected as the HTML editor, or has something perhaps changed?
Unsickle
1,016
The HTML editor is for the "Edit" option. View Source should default to notepad unless you change it in registry... which I didn't do.
Aiiyah.
Unsickle
1,016
Same thing, no work. Here are the steps that have failed thus far:
1. Delete cache, both through the IE options, and manually as well, followed by restart
2. Delete cookies, both methods, followed by restart
3. Search registry for noviewsource, nothing found
4. Yes, notepad is operational and in the original place
Basically it was working, and then stopped and has not worked since.
LordMaul
15,168
Solution: format c:
Unsickle
1,016
I got desperate (I have been with women, but now with the computer) and did an XP restore from two days ago. That fixed the problem.
Thanks for your patience.
