Right Click Hang ***[Solved]***
Redstorm
293
Something has happend to my installation of Windows XP so that when I right click on a text file (or any other file for that matter) the machine hangs for 10 - 15 seconds before bringing up the context menu.
I have run Ad Aware and hijack this and removed any spyware found.
I have even reinstalled windows XP over the top (upgrade) and still the issue persists.
I have tried using a standard VGA driver and still the issue persists
I have downloaded 71.89 of the forceware drivers and they did not fix the issue.
any other suggestions on where I should be looking to solve this one would be apprieciated.
newbiepcuser
4,474
I had this happen to me a while back going from ti4200 to 4600. Uninstall all the nvidia video drivers and rerun it. You might have to get driver utiltiy cleaner also. give this a try. Use the Nvidia video drivers though. Make sure you include the Nvidia desktop utility. good luck
FlyingPenguin
1,793
You probably installed something that added a right-click context menu item and that app is slow to respond. Easiest fix is to use system restore to go back to a restore point prior to the problem occuring.
Redstorm
293
Solved.
Right Click context menu can be the culprit and thier is a good artical on how to trouble shoot it here:
Slow Right Click
This was not found to be my problem and upon further investigation I found that Right-click is extremely slow only when the Network is enabled.
The solution can be found here:
Right Click is extremely slow only when Network is enabled
In my case when I searched the registry for the machine name of my old PC as this is the only other PC on my network, what I found was that FlashFXP.EXE was trying to launch from the networked PC that when it is OFF causes the slow right click behaviour. I cleaned up these entries and bingo all is well.
I even remember that after building my new PC i ran Flash FXP from the network share on my other PC as I had not installed it on my new PC yet to transfur some files from my XBOX, little did I know the performance impact this little act had on my PC.
Mental note to self - Don't run apps from the network unless the machine is on 24x7
