natto fire
So this thread is kind of a long shot, as I am already going to pull the trigger on a carb rebuild kit, but I wanted to pick a brain or two.
I have an 18.5HP B&S twinII motor that ran perfect when I put it away last fall. I went to start it up today, and it did run for a minute, but died when I tried to throttle up.
I took the air cleaner off and noticed that it was dumping fuel, a crazy amount, into the air box. Like a geyser of gasoline that soaked the filter and puddled in the air box.
I took the carb apart and didn't notice any diaphragm obviously broke, so I am worried about a carb rebuild fixing the problem.
The fuel system is all gravity fed, so it is not a pump issue.
Sent from my XT1585 using Tapatalk
