Riding in a lowered car for more than 10 mins is pure torture
Vic
50,422
14,333
Originally posted by: phantom309
I had Eibach Pro-kit springs on my WRX wagon for a while. Eibach claims they're designed to work with the stock struts, but they didn't do well at all. The drop looked great but it rode and handled much better stock.
Did you have the wagon specific springs?
Also, the struts on the bugeye years (02-03) didn't have a lot of dampening (especially the rears), and lowering springs had a tendency to make that worse. Hit a bump going fast around a corner and the rear had a tendency to unweight in a hurry, which could be a bit startling. Good aftermarket struts (like KYB's or Koni's) fixed that issue.
DivideBYZero
24,117
Originally posted by: Vic
Originally posted by: DivideBYZero
Not only that, but I would wager he has done nothing to the suspension geometry either.
:Q
My WRX sits on KYB AGX adjustables and Eibach Pro's, plus sways, camber kit, and custom alignment. It's my daily driver, so I felt it was a perfect compromise between ride comfort and performance.
The OP's friend sounds like a ghetto ricer. Sometimes it's better just to leave that Civic stock.
You should look into getting the bump steer mod done, too. I didn't have my Wagon done, as I had the Prodrive Fast-road Geometry set up and it drove like a dream and the ride was sweet as I was on the stock JDM WRX springs.
fbrdphreak
17,555
Originally posted by: jtvang125
Originally posted by: Aflac
what car?
personally I don't care for lowered cars. It looks kinda cool, but when it comes down to it I would be paranoid of ruining the car bottom when going over a hill/bump.
A civic lowered on 'fake' coilovers. It's pretty slammed. The tires are tucked a bit under the fender. That's too low for me. I prefer a lowered look like on the bmw's.
That explains why. I decided not to lower my car with aftermarket springs, but from what I hear it doesn't make it a lot harsher.
But if you don't use the proper equipment or you just don't care about ride quality, then you're going to have the typical Civics that go bouncing down a perfectly flat road.
Unheard
3,773
9
Admittedly, my ride is a little harsh right now, but I still have a little work to do. I need to C-Notch the rear frame, and go with after market bumpstops. After that is should ride almost factory.
Raduque
13,140
138
My car is lowered, but I don't know how. It has coilovers up front, and the ride is pretty harsh, but it doesn't bounce. Plus it handles very nicely, easily outhandles my mom Eclipse and my friend's Sentra. So, just because a car is lowered doesn't mean it's crap, even if it is a Honda.
