Blue Shift
- Feb 13, 2010
- 272
- 0
- 76
Uhhh, an xbox is 250$. Are your saying i have to pay more than quadruple that to play my games with alittle more eye candy? I dont want to play all games at MAX settings, i just want medium to high.
You can run most games at high settings with that system, assuming that you're fine with 30 frames per second at 1920x1080. If you want a little bit more performance, consider stepping up to a Radeon HD 6950.
Remember that the XBox 360 usually renders things at 30fps at 1280x720, then upscales them to fit the device. There may be some games that run at 45fps or 1920x1080 native, but not many. Most PC gamers want double the framerates at double the resolution, with textures at least four times as large. That's before you even get into advanced lighting and filtering settings.
$600 buys you a system with a GPU at least 4x as powerful as the one in the 360... Unfortunately, that's not enough for most people.
Edit: You've selected parts for a system with a Performance-class CPU and a mainstream GPU. Your performance in most 2011 games will be, well, mainstream. That means decent (medium to high) settings at 1920x1080, at playable framerates.
