skinnypotbelly
For those of you interested I just did a comparison of the shogun against the 9500. System as follows:
amd 4800, stock, at 1.36v
2 x 1gb ballistix, running at DDR400; timings: 2,2,2,5 at 2.78v
seasonic s12 600
evga 6200tc
antec p180
evga sli mobo
scythe shogun w/ 96 cfm masscool fan or zalman 9500
Before i give the results this evga mobo is known for giving bad temp readings. The consensus is that the temperatures are anywhere from 7-15C off. Both coolers were connected directly to a molex connector. The temps were read by MyGuard, a jetway temp measuring program that works on evga boards.
shogun idle: 41 cpu, 39 system
load: 56 cpu, 44 system
9500 idle: 41 cpu, 39 system
load: 63 cpu, 50 system
Load temps were read while running two instances of prime. The 9500 was just installed so I plan to check temps again the next couple of days.
seasonic s12 600
evga 6200tc
antec p180
evga sli mobo
