- Dec 8, 2010
- 11,897
- 74
- 91
忍者四 SCYTHE NINJA 4: the noble art of processor cooling
I upgraded my rig from Ivy Bridge to the new Skylake, and decided to also switch to a new cooler. The previous Scythe Mugen 2 would surely have done the job adequately, however I felt that new parts deserve a bigger and prettier cooler. Because when it comes to CPU cooling, big is pretty:
I bought the Ninja 4 for 47.90 euros, which isn't too high of a price given the size of the cooler. Before we get into the meat of the matter, let's absorb some background information:
Scythe Ninja 4 features
- 780 g heatsink with six 6 mm heatpipes and a nickel-plated copper base
- Scythe Glidestream 120mm PWM sleeve bearing fan with a wide RPM range
- good compatibility with different sockets, and being only 155 mm tall, it fits many of the narrower tower cases as well
- beautiful, distinctive, symmetrical shape, its face embossed with a Japanese shuriken
Installation
Ninja 4 is fairly straight forward to install by following the instructions, however, the final part where the heatsink is secured on the installation bracket requires a bit of finesse. The screw holes are accessible only through the narrow vertical gaps in the heatsink. While attaching the cooler, the motherboard has to be horizontal, and a flash light is quite useful. All this is slightly awkward, but I can't think of a better way to install a cooler of this size and shape, so no points are taken away.
It comes supplied with a Phillips 2 screwdriver, which is good news for those building their first rig: the user doesn't need to bother acquiring a screw driver for installing other parts.
On my motherboard, the heatsink itself covers the first DIMM slot, while the attached fan overshadows the rest:
This is not a problem in and of itself, as standard profile memory fits with no issue. The first DIMM slot should be just about accessible without removing the heatsink.
Test bed
Serving as the test bed, we have a test bench modded from an old ATX tower (more information in my thread on the Finnish site MuroBBS):
- CPU: i5-6600K (not delidded)
- Motherboard: Asus Z170M Plus
- RAM: Kingston 2x4GB DDR4-2400
- GPU: integroitu Intel HD 530
- SSD: Samsung 840 EVO 250GB
- HDD: WD Black 3TB
- PSU: Seasonic G-650 (SSR-650RM)
Test methods
Thermal paste: Arctic MX-4
Monitoring: HWiNFO64 and a digital thermometer for monitoring ambient temperature
The fan profile for both the case fan and the CPU fan is set to Standard in the motherboard BIOS. The CPU fan RPM does not reach its 1500 RPM maximum, instead it caps out at 950-1200 RPM depending on temperature in these tests.
Temperature testing was done mostly with Prime95 v27.7. Here are the tests I ran:
- TEST 1: Temperatures at different clock speeds: AUTO, 4100, 4200, 4300, 4400, 4500 sekä 4600 MHz. For each overclock, the lowest stable voltage was first acquired.
- TEST 2: 4500 MHz overclock investigated with Prime95 v28.5, IntelBurnTest 2.54 and x264 Stability Test programs. The first two stress the CPU more than P95 v27.7, whereas the x264 test reflects the maximum temperature you can expect in real world use. For more info on Skylake stability testing, see the OCN thread.
- TEST 3: Temperatures with the lowest fan speed, and with no fan at all (rear 92 mm fan still installed)
Test 1: Temperatures on different OC settings
Alright, bring it on!
I have to admit, I didn't quite expect such performance from a sub 50 euro cooler. One reason for this may be that in my previous setup I was used to the HyperThreaded i7-3770K. HyperThreading considerably increases heat output. In any case, temperatures stay well within safe margins in an unrealistically high load, even at a voltage which borders on the unsafe for this CPU and my entry-level Z170 board. Intel allows a maximum of 1.45V for the i5-6600K, but with my 4-phase VRM motherboard I'm not really prepared to go past 1.4V.
Temperature differences between cores were very small (2-5 degrees celsius depending on OC setting), but this is probably not to the credit of the Ninja 4. I think I just happened to get a CPU which heats up evenly, possibly due to thermal paste being spread evenly under the IHS.
So, what else can you hope from a cooler than temperatures low enough that the cooler doesn't become a bottleneck when overclocking? Well, you can certainly also hope for quiet operation in heavy loads. Scythe Ninja 4 is by no means silent - the maximum RPM at the highest clock speed was 1200 RPM which could put off those seeking a super quiet cooler, but should not bother most users. At idle, the fan (at Standard profile) runs at about 750 RPM which is very quiet (the WD Black hard disk is noisier). With Asus "Q-fan tuning" (which calibrates a new minimum RPM) I was able to lower the minimum to 600 RPM. It's possible to lower this even further, see Test 3.
Test 2: 4.5GHz in different stress tests
Code:
Stress test °C
x264 stability test 61
Prime95 27.7 69
Prime95 28.5 73
IntelBurnTest 2.54 73
4.5GHz stays as cool in the real world load that is the x264 benchmark, as it does at 4.4Ghz in Prime95 27.7 (see Test 1). The same can be expected when comparing 4.6Ghz to 4.5Ghz.
Test 3: Performance at low RPM and passively cooled
The Glidestream fan has a handy manual switch with three settings, High, Medium ja Low:
According to official specs, M and L lower the maximum RPM to 1150 and 800, respectively. Apparently M lowers the operating voltage from 12V to 7V while L lowers it further to 5V.
The minimum fan speed in my testing was 400 RPM for both M and L settings, and 600 RPM for the default H setting.
According to this test, even the hefty 4.5GHz overclock stays cool enough at a practically silent fan speed. For comparison, the Standard fan profile achieves an RPM of 1050 and 14 celsius lower temperture.
With no fan at all, the cooler performs admirably in cooling a light overclock at low voltage. The downside with passive cooling, however, is that the heatsink stores more heat and the processor stays quite warm (about 50C) for several minutes post-load. The surrounding components also suffer, as there is no fan to move air around the heatsink. Even though passive cooling is easily feasible, I recommend people to use a fan at low RPM. If you have even one other fan or one hard disk installed, passive cooling does nothing to benefit the PC's noise output compared to running a very low RPM CPU fan.
Conclusion
Scythe Ninja 4 is without doubt a high performance cooler. With i5-6600K, it is practically impossible to create high enough temperatures in normal use without at the same time supplying unsafe voltages to the CPU. To properly bring out the limits of this cooler, you need an overclocked i7. For CPU's less demanding than an i7, Scythe Ninja 4 makes it possible to run a nice overclock at a practically silent fan speed.
With respect to cost, Ninja 4 is mid tier. Unfortunately, pricing info doesn't seem to be available for North America. In Europe, you might be able to find the same performance for less cost (Thermalright HR-02 for instance), but at the same time the Ninja 4 is not too highly priced because one of its main selling points is the distinctive, beautiful design.
The Good
+ excellent performance for heavy i5 overclocking or somewhat lighter i7 overclocking
+ appearance
+ compatibility
+ PWM-fan with Low/Mid/High settings
+ compatible with other 120 mm fans
+ supplied with a Phillips 2 screwdriver
The OK
* cost
* installation
The Bad
- I'd gladly pay a little more for a long-life FDB or other bearing fan
- not compatible with 140 mm fans
- short 1 year warranty
- availability
Score: 8/10
