- Jun 23, 2001
- 27,730
- 8
- 0
I plan on building a new system in early August, most likely around an AM2 A64 chip and an X1900XT(X). The AM2 CPU is a good bet, but the videocard is subject to a lot of change, there are rumors of a die shrunk X1900 core launching 'soon'.
This is also my first water cooling setup, unless you count the Tidewater on my videocard. Regardless, this is a little more indepth. Please, feel free to point anything out with this setup.
CPU Water Block - Swiftech Apogee CPU Block
Water Pump - Swiftech MCP655 12VDC
Radiator - Swiftech MCR-220 Dual 120mm
Reservoir - Swiftech MCRES-Micro
VGA Block - Swiftech MCW60 + 8 Ramsinks
A side note on the VGA block, I saw these as well. Now, I believe they make an ATI version as well. Would getting a water block that covered the RAM be worth paying almost double?
Tubing - ClearFlex 60 tubing 1/2in ID 5/8in OD
The plan is for this entire setup to be enclosed inside a Lian Li PC-V2000B with windowed panel.
Lastly, I had some debate over the coolant as well. Distilled water vs some sort of UV reactive coolant, such as Swiftech's Hydrex.
I believe all the parts I listed above use 1/2in connectors, as well as the tubes. Should I purchase additional clamps, gaskets, etc, or will the parts the themselves include those parts?
Comments?
Comments?
