Return To Castle Wolfenstein Single Player Help (2nd question)
Mrfrog840
Ok 2nd Question.... why in the heck wont my weapons zoom. I mean any of them. i binded the zoomin key to / and zoomout to . This is pissin me off. All i can use are binoculars
The one rifle you're supposed to recover is in a building at the back end of that compound. When you are facing the gate, go to your left and all the way back.
yeah, but i dont think thats the one you want, is it? are you looking for the "wet" one that lets you see thermally?
i'm not sure which level you are on cause i haven't played it in a while. is this the level where you have to get into a truck to enter the compound? if so, the Special rifle i believe is by the first tower on the other side of the tunnel. there are 2 men by the tower and one is going to go check on something. These men are on the ground and by a gatlin gun. The man that is going to check on something is walking toward the rifle. the rifle is behind them in the hills. look around and you'll see a parachute in a tree.
Yes the wet one. right now im quicksaved at the part where the truck leaves. Where do i go from there? across the pond is just a colt with 30 bullets
if your in the pond, head the other way I believe. you have to make your way around and you'll see a building and some towers. sneak around the towers and you'll come to a tunnel. go throught the tunnel and the "wet" rifle is on the other side. explained very badly in my first post. 😛
EDIT: edited previous message so refresh to read it.
yeah, ricerx is right.
the truck will go over a bridge and you should stay to your right and follow the path that is outlined in your notebook. you will then find yourself in a tunnel. then go through the door on your right side that's midway through the tunnel. it will take you above ground and the sniper rifle is down the path... far behind the ground mounted gun.
Go across the bridge and through the tunnel. There will be a guard tower and machine gun on a little rise. Walk towards and past them and near a tree you will see the parachute and there will be the rifle.
Marty
<< Ok one more question. When the truck goes accross the bridge i dont follow it?, i go the other way around it? >>
you won't get into the truck till later after getting the rifle and entering the first part of the compound.
follow Whitelights instructions about the door and getting to the 2 men.
