Return to Castle Wolfenstein problem
Sully
300
When I load RTCW it feezes and I get a BSOD (blue screen of death) or a nv4_disp.dll looping error. This will occur most of the time it is very annoying. I know there is an issue with the nividia 23.1 driver and Windows XP . When i play RTCW it happens all the time. Please help.
InFecTed
874
Install win98se, run it again and see all BSOD problems disapear. I've tried for weeks to get XP to work, no f*cking way. Now back to win98se/win2000:)
BFG10K
22,709
3,003
This issue has been in the forums for weeks. Download the latest BIOS for your motherboard and download the latest 437 4-in-1s and it should fix the problem.
RolyL
258
Windows XP Pro, GF3 23.11, 761/686B works fantastically for me. RtCW /does/ work under NVIDIA + XP.
Sully
300
I have installed the motherboard bios 8k7a1a17 and the latest Via driver 437 and still have the same problem.
cubanx
610
You might want to remove 1 stick and try... My video card driver's would go BSOD if I fill all 3 slot's on my VIA Chipset board. This happens on both Nvidia and ATI cards. Via has had/has stability problems with all Dimm slot's filled on some boards. I overclock my CPU also. I leave 1 DIMM open and no BSOD problems. It sux i know.
nitrousninja
1,095
Try uninstalling it and then reinstalling it from another drive. It might be an I\O conflict like I had. A BIOS flash cured mine but it couldnt hurt for you to try. Good Luck!
ChuckWits
242
I can't seem to get RtCW bright enough, and also Everquest as well. I have an older monitor (Princeton Graphics EO70) and the brightness is all the way up...could it be just worn out? Web pages are fine though.
Maybe it's time to look into a new flatscreen :)
