Return to Castle Wolfenstein and OpenGL on XP
JoshFink
110
I just downloaded the Return to Castle Wolfenstein MultiPlayer test. I'm trying to run it and it gives me the folowing error. I'm assuming that openGL is not working for some reason. I'm running this on a PIII-650 Laptop with an ATI Rage Mobility Video Card.
Any thoughts? Thanks
Wolf 0.7.15 win-x86 Sep 15 2001
----- FS_Startup -----
Current search path:
C:\Program Files\Wolf MP Test/main
0 files in pk3 files
Running in restricted demo mode.
C:\Program Files\Wolf MP Test\demomain\pak0.pk3 (1471 files)
C:\Program Files\Wolf MP Test/demomain
1471 files in pk3 files
execing default.cfg
couldn't exec wolfconfig.cfg
execing autoexec.cfg
Hunk_Clear: reset the hunk ok
...detecting CPU, found Intel Pentium III
Bypassing CD checks
----- Client Initialization -----
----- Initializing Renderer ----
----- Client Initialization Complete -----
----- R_Init -----
Initializing OpenGL subsystem
...initializing QGL
...calling LoadLibrary( 'C:\WINDOWS\System32\opengl32.dll' ): succeeded
...setting mode 3: 640 480 FS
...using desktop display depth of 32
...calling CDS: ok
...registered window class
...created window@0,0 (640x480)
Initializing OpenGL driver
...getting DC: succeeded
...GLW_ChoosePFD( 32, 24, 8 )
...35 PFDs found
...GLW_ChoosePFD failed
...GLW_ChoosePFD( 32, 24, 0 )
...35 PFDs found
...failed to find an appropriate PIXELFORMAT
...restoring display settings
...WARNING: could not set the given mode (3)
...using colorsbits of 16
...calling CDS: ok
...GLW_ChoosePFD( 16, 16, 0 )
...35 PFDs found
...35 PFDs found
...shutting down QGL
...unloading OpenGL DLL
...assuming '3dfxvgl' is a standalone driver
...initializing QGL
...WARNING: missing Glide installation, assuming no 3Dfx available
----- CL_Shutdown -----
RE_Shutdown( 1 )
GLW_StartOpenGL() - could not load OpenGL subsystem
Compellor
889
You could try running your desktop in 16 bit color. Try changing the resolution in the game to 800 x 600 or higher. There are reports that there was a corrupt version on the file from Gamespot. I'm not sure if you would be able to even open it--let alone play it. I know the ATi rage had some driver issues with OpenGL. Are they the latest drivers?
NFS4
47
The default Windows XP drivers don't have full OpenGL support. It's as simple as that. It does the same thing to me when I run Wolf3D with the default XP AIW Radeon drivers.
If I load the Win2k drivers, it works just fine.
JoshFink
110
Thanks.. I loaded the windows 2000 drivers and it works fine now.
Any idea why the Windows XP drivers don't have full opengl support and is there anyway to use those and get the opengl support?
Thanks,
Josh
SilverThief
5,720
HOw does the game look? I saw some screen shots of it a while back and it looked pretty damn tight.
Cant wait to play it.
Def
765
It looks pretty good, but not as amazing as everyone was touting it to be IMO. The fire effects are really cool though. :D
But for some reason I don't have sound. This is on XP Professional with a SB Live! value card.
m2super
323
game looks great 1280x1024x32 everything maxxed out! The flamethrower effect is incredible!
Its worth checking the demo to see for yourself!
wluk
Guest
Feb 2, 2001
1,676
<< I just downloaded the Return to Castle Wolfenstein MultiPlayer test. >>
Where can I download a copy? Thanks!
