Retail Tbird 1100 + MSI Pro2A: underclocking results!
Leo V
3,123
This is part of my quest for a quiet PC, and so it belongs in General Hardware.
I'll sum up my results this way: underclocking turned out unnecessary! I must've gotten a really good chip, because it runs stable at:
1) 1250MHz at default voltage (1.75V)...must've been using like 70W!
2) 1200MHz at 1.675V
3) 1100MHz (rated speed) at 1.525V!!! :)
I'm using MSI K7T Pro2A with their latest "power user" BIOS--hence the fine voltage adjustment. Unfortunately, the BIOS still doesn't allow reducing I/O voltage (which is always higher than the official figure).
Stability was first tested with Prime95 and CPU Burn-In (error checking). However, sharkeeper was kind in sending me BurnK6.exe--this program fries your Athlon to the highest possible temperatures! Well guess what... after 15 hours of BurnK6, my CPU temperature barely surpassed 36 Celsius! (It was 50C at 1250MHz/1.75V). The CPU heatsink is just warm (currentyl using AMD's bundled retail cooler). During normal operation, the heatsink is barely lukewarm.
CygnusX1
110
Hi Leo,
Are you using a fan on the heatsink? I'd be interested in hearing your system specs (power supply, case fan, etc.). I just finished building a quiet performance machine.
Mark.
Leo V
3,123
CygnusX1, I'm currently stuck with AMD's loud retail HSF--the only fan in my system. I'm getting a copper Molex Radial socketA cooler from QuietPC soon--it's rated at 22dB, so should be inaudible outside the PC case+desk drawer.
Charles
2,115
Cool. 1.75V should be displayed 1.8V in MBM or other similar program right? So 1.525V should be 1.575V, right?
John
Moderator Emeritus<br>Elite Member
Leo, I hope you are enjoying that board I sold you. :)
Nice results !
CygnusX1
110
I got the Molex PIII cooler and 300W power supply from QuietPC.com and am very happy with them. My case (Lian-li PC60) came with three fans. The front two are attached to a switch that allows me to run them at 7, 9, or 12 volts. I have them running at 7 volts and the computer is quieter than my previous computer with a Golden Orb CPU cooler, and PC Power and Cooling Silencer 275 ATX power supply and Silencer Case fan. The fan/hard drive noise is still more audible than I care for. I'm thinking about replacing the three fans with Papst fans and perhaps trying out the Quietpc.com Silentdrive enclosure. Any case fans in your system?
Mark.
Leo V
3,123
John, you bet! By the way, I've left you positive feedback just recently--before that I was offline putting everything together ;)
CygnusX1, my only fan right now is the CPU fan. I even unplugged/removed the fan from my QuietPC 230W PSU. This was a bad idea, because it can get pretty hot. Until I receive the fan back (I had already sold &amp; shipped it!!) I'm running open-case.
Once the dust settles, I'll have 2 fans: the Molex Radial fan, and the QuietPC PSU fan. The Enlight 7237 case has good enough ventilation, so I don't plan to use any more. (In fact, I'm still angry that I'll need more than one.) My computer will go into a wooden drawer, and I'll pad the drawer with noise-absorbing stuff.
Charles, you're correct--the official BIOS settings (currently 1.525V) and the reported BIOS readings (currently 1.59V) don't agree. I used the &quot;official&quot; settings, since that's what everyone compares--I'm guessing that &quot;Radiate&quot; uses these &quot;official&quot; settings.
Mikewarrior2, I think it may be even lower--possibly <40Watts. Radiate seems to give the *absolute* highest possible heat dissipation. For example, AMD officially states that Tbird 1.1GHz eats ~49Watts at normal voltage (1.75V). Radiate says ~59Watts. If we apply this proportion to 1.525V, I could very well be at ~39Watts! :)
Mikewarrior2
7,132
there's a newr version of radiate. 1ghz 1.75 v is around 50, but 1.8V pushes it to 54, then 1.85 goes to 58.
Mike
Marty
Banned
Oct 11, 1999
1,534
Quiet computer? What is that? ;) Good job though...
Could you send me a copy of that CPU burning proggy? This 1100 at 1300 is rock stable at the default voltage running RC5 24 hrs a day, but I want to try something more cache intensive.
Send it here please.
Marty
Leo V
3,123
Mikewarrior2, could you please link me to the new Radiate program? Thanks.
Marty, YGM.
Mikewarrior2
7,132
I'll post it once I get home.
Overclockers Utilities
Hmm... its still 58 for a 1100mhz chip. I think it is worse case scenario, but i think most load programs(ie seti@home/prime95/rc5) push it closer to radiate's limit than to AMD's number.
Mike
Mikewarrior2
7,132
One thing, where did you read about 1100mhz cpu's using 49W?
AMD's white paper(23792.pdf) states that typical thermal power is 54, with max at 60, i would think that radiate is pretty darn accurate.
Mike
Leo V
3,123
Mikewarrior2, you're probably correct. I searched through Google and found some old Tbird1.1 review by an AMD fan. Their math was probably wrong.
Charles
2,115
Leo, do you mind sending BurnK6.exe to me please.
Thanks a lot. Grrr, your PC is even quiter than mine. I thought mine was quiet :). You have 2 fans, and I have 4! I wish that I can get rid of that video card fan and the PSU fan.
LXi
7,987
Everybody is on quest to have the coolest and potentially loudest PCs by throwing in a million fans and modding their case and so on, its very nice to see Leo V who goes for the complete opposite direction.
Doomguy
2,389
Watercooling is the best solution. The pump is virtually silent and you can overclock higher than with any heatsink. Its also very safe if you buy a kit.
Charles
2,115
I'm running My 1Gig Tbird at 1.65V (Displayed as 1.70V), the temp is hovering between 39-44 degrees celcius. Not bad considering I replaced the loud YSTech fan on my Alpha PAL6035 with a quiet low RPM Adda fan.
I didn't try lower voltage cause I think 1.65 is low enough :)
bluesky
1,325
Well, maybe out of topic.
Is there anyway I make my case fans quieter? I have 2 fans on Antec 830sx. It's pretty loud. I don't hear any other noise from my computer because the case fans(I believe these are 80mm.) are so loud.
Thanks very much.
Leo V
3,123
The main reason I haven't succumbed to water cooling is my anticipation of the CALM system, supposedly due out this January for $99 USD.
Spook
2,620
Lets see if it works... Sounds cool in concept... I know that Dell, at least they used to, would put a heatsync on and extenders, that would allow it to touch the metal case, to use it to disapate heat... This one sounds a little more scientifice about it though.
Put a good 300w PS, and a silient case, and we'll be off and running... Stealth Case.. Make it black..
Bignate603
13,897
anand reviewed a phase change sort ofcooler a while back, it didn't work horribly well and he thought that the technology wasn't given justice...
joeryu
1,678
can you send me that proggy burnk6, i wanna test out my tbird 750 that is at one gig and 1.6 volts, and i wanna try lowering the voltage as much as i can while staying at gig.
DJ_Donut
129
why not get long cables and put your rig in another room? seem like the easiest way to get a silent comp.
btw that CALM system seems like another vaporware to me.... I emailed those guys and they told me that they're having technical difficulties to make it into production.
