Hi all,
I'm new to your forums and have a bit of a problem with my allendale....
I use E6300, DS3 bios F4, Zalman 7700, 2*512 Corsair XSM2 6400, GF7900GT.
The problem is terrible temps, at 450*7 stock voltage E6300 idles at 47c and full load 65-68c according to EasyTune5.
Other programs, such as Coretemp or Everest or SysTool report approx.10c higher. Bios readings are in line with Easytune5.
I reset the cooler 6 times, with 3 different thermal pastes, no change or for worse.
Contact seemes ok, best results with adding paste only to midle of the heatspreader. If I spread it all over it, temps will rise.
And I know the amount to use...
Is it possible either the zalman or E6300 is slightly bent so it will affect temps but I dont see it when I take the cooler of...?
Does bios version affect cpu diode readings?
