P pdampier Member Oct 3, 2000 55 0 0 Oct 4, 2000 #1 If I remove the heat sink/fan from a retail intel C633 is there a big mess of thermal compound left on the CPU? I'd like to cleanly remove it, apply some thermal compound to the CPU and then add my Gorb on top... Easy to do? Advice? Links? Thanks!
R rigor2 Banned Sep 18, 2000 183 0 0 Oct 4, 2000 #2 the retail white stuff is not grease, its a thermal pad. So no, theyre won't be any grease left on the chip. Better put some on.
Homerboy Lifer Mar 1, 2000 30,890 5,001 126 Oct 4, 2000 #3 which works better the pad or normal grease... obviously arctic silver is the best but pad vs normal grease?
P pdampier Member Oct 3, 2000 55 0 0 Oct 4, 2000 #5 Does the pad come off easily or is it a razor blade job?
Homerboy Lifer Mar 1, 2000 30,890 5,001 126 Oct 4, 2000 #6 smokin' at 950 now after removing the thermo pad and tossing on some grease. MUCHO BETTERO! THANKS!
