Rob_63
I have an 890GX chipset Asus board that hard locks whenever it goes into sleep mode, the only way to wake it is to turn off the PSU and drain the residual power, then press the start button, then it goes to the log on screen.
The board is an M4A89GTD Pro/USB3
This only happend with winders 7, I had Vista ultimate on it and it worked fine.
I have S3 set in the bios (auto did the same).
The system sleep works fine after a fresh install and it is after I start updating windows that it starts to lock up.
I was running a 790FX Asus board with the same OS and it worked fine, but this board has me ready to take it to the range and blast away at it.
Any ideas before I lock and load?
Thanks!
Thanks!
