Restarting Problem Automatically
Tecnic2001
28
How are you doing i'm new to these forums so be nice to me just kidding, well i just put together this new computer with the asus a7v8x motherboard everything set to default in bios. I recently had some problem with some memory I bought from a dealer which was a pc2700 module in which i would get a blue screen saying memory management error, so i returned the memory and got a another stick. The computer know seems to work fine............but once and a while for now reason for example i might start fs2002 and then the computer restarts automatically or i might put a cd in and the computer restarts itself................................AND SOMETIMES.................i turn on the computer to the desktop screen everthing loaded up and it restarts itself again................................I can't seem to find the problem is it a hardware issue or a software issue cause this happen on my other hardrive i also i have removable hard drive tray................It has to be either the memory again or the motherboard............................COULD YOU GUYS give me some ideas or could you recommend another motherboard that is KT400 WITH AN 8x agp port......................................ANY HELP WOULD BE APPRECIATED.
CLUE: ALSO ORIGINALLY WHEN I WAS USING A PC2100 stick of 256 ram before i bought the pc2700 ram it was doing the same thing..................could it be a wiring problem i did.......................
CPU: AMD Athlon XP 2200 1800MHz @ 1800MHz
Motherboard: ASUS A7V8X KT400
Memory: 512 MB of PC2700 DDR
Video Card: Visiontek Xtasy 128 MB (GeForce 4 Ti4600)
Hard Drive: Seagate Barracuda 80.0 GB @ 7200 RPMS
Additional Hard Drives: Maxtor 30gig HD 5400RPMS
80 Gig Seagate Barracuda 7200rpm
Monitor: IBM 19inch G94 MONITOR
CDROM Manufacturer & Model: ACER 56X
CDR/CDRW Manufacturer & Model: SONY 48X24X48X
Storage Interface: IDE
Sound Card: SOUNDBLASTER Audigy Gamer
Internet Provider: RoadRunner
Internet Connection Type: Cable
Internet Connection Speed: CABLE MODEM
Operating System: Windows XP Professional
Other Components: Altec Lansing Speaker System
500wtt Power Supply
Lian Li Rh10 Removable Hard
Drive Unit.
Hewlett Packard 940c
Saitek ST200 Controller
Notes: Mobo Raid Capable.
Alphazero
1,057
The symptoms you describe are almost always caused by the power supply. Check that out - try a different one, or try unplugging some devices (lots of drives in there). I noticed you have 500W, but it's the brand and quality that count.
Tecnic2001
28
I understand that but the only thing is that i never had this problem with the power supply its fairly new about 1 year i bought it from COMPUSA ITS their brand.................with the other motherboard an asus a7v-266-e i never had a problem.
Tecnic2001
28
I also just replaced all the ribbons for the harddrives and the cdrom and cdr lets see what happens. i 've also unplugged everthing i tried to eliminate some things.......no go on that.............but the only thing is this doesn't happen constantly just once and a while..................To tell you the truth i'm looking at the soyo kt400 model the newest one..............................
